My crystalyte kit arrived and I started fitting it to my mountain bike but came accross a few issues.
After modifying the controller (with instructions from Crystalyte) to disable the pedal assist so that I could use the thottle only, the following problems stopped further assembly:
1) The battery box can be mounted under the frame, as I expected it could, however due to the very long suspension travel, my front wheel would be able to hit the battery box.
2) The Crystalyte 408 rear hub can take a disk brake, however my 4-pot calipers are too large to fit between the disk rotor and the hub body.
PLAN B!!
As a temporary measure, and for experimentation, I fitted the kit to my commuting bike (hardtail mountain bike with slick tyres) and I have to say I LIKE IT!
I spent a good amount of time riding around and testing what it could do. Its not fast (feels like about 17-18mph), in fact no faster than I could pedal myself, but so much less effort. And hills? What hills?!
Next on my to-do list:
1) Buy a quality speedometer so I know how far/fast/long I can ride per charge.
2) Buy a rim to match the front, and rebuild the wheel. (I want to keep the commuter's old wheel intact for emergencies).
3) Investigate alternative disk brakes which might fit.
4) Investigate other battery mounting options for my mountain bike. (Not keen on a carrier set up, since I'd prefer to keep the weight more central).
All in all, I'm pretty happy with my first venture into ebikes!
PLAN B!!
