Hi, My name is Bob and I am an unfit,mid fifties,17 stone bloke in need of some exercise .
I live in Teesdale England which is very hilly so decided I needed an electric bike so that after riding away from home I could return(uphill) without having a heart attack so I bought a very second hand Cyclamatic.
It’s better than my standard Trax mountain bike but not by much as most of the hills round here are 14% or steeper so I decided to buy a 1000W kit.
After a couple of months research I decided on the Dillenger 1000 watt kit with a 10Ah battery.
http://dillengerelectricbikes.co.uk/shop/1000w-10ah-high-powered-electric-bike-conversion-kit/
It came this morning and I fitted it in a couple of hours but didn’t bother with the RPAS or brake levers yet as I wanted to know how well it would cope with the hills first.
It was an extremely simple kit to fit except that the rear rack mounting bracket was too big for my seatpost!
I made a temporary fix with some “O” rings and insulating tape and have now sourced some rubber to make a better fix tomorrow.
The battery took 3 hours to charge then it was time for a first test,wheel up in the air and throttle wide open it reached 69.5Kph which was a bit of a nice surprise.
The motor does have a bit of drag but its very little and the bike(Halfords Trax 18 speed budget mountain bike) can be pedalled unpowered without too much effort.
I should maybe point out here that the kit came with a torque arm although it was not on the kit list.
First run up the road with quite a strong side wind gave me 33.8 Kph on the flat and 24.3 Kph going up a 10% hill of about 300 metres,not bad as that was all without touching the pedals.
I then did a further 4K on slight hills pedalling with the throttle wide open and in top gear I was pedalling as fast as I could downhill to try and keep up with the motor,on the slight uphills it was still possible to stay in top gear as well.
Next I went down the 14% Billy bank and got halfway up the 24% hill at the other side(in 2nd gear but still going) when I got a puncture(in the rear wheel). I had to push the bike over a K home up the hill but it was not too bad as the kit has a “walking” setting where you hold a button on the lcd and it powers the bike at 6Kph.
I have ordered a pair of Kenda puncture resistant tyres now and they are 1.5 wide smooth tread rather than the 1.95 knobblies that were on so may give me an extra Kph or 2.
The biggest problem with the current setup is the disc brakes which are pretty pathetic but luckily there is quite a lot of engine braking when you roll off the throttle.
I will try and repair the puncture tomorrow so I can have another go but if its not successful I may install the pedal sensor so I can try that out when the new tyres come.
My goal is to be able to pedal to my local pub(3 miles away all downhill) and then be able to make it all the way home with ease.
