If its hurting it may well be doing your knees damage you'll regret in a few years time. There is a big difference between 40 and 34 at the front, but the difference between 44 and 46 is much smaller.A 46 will be harder to pedal than a 44 in the same gear, for sure. You need to look at your lowest and highest cogs on the cassette to work out if a 46 will be too hard. When I went from a 34/50 to a single 40-tooth, I found I was using the higher gears almost exclusively. Getting up steep hills is harder in a 40/32 gear (versus a 34/32), but my view is that if its not hurting, its not working! So I am happy to compromise.
Thanks for advice appreciate that it’s too late now lol I jumped the gun and paid for the bits o well il learn the hard waySimon get them SNAIL brand (104bcd) direct from China via Aliexpress sellers, they are 4 or 5 X cheaper then the same ones on Ebay where British sellers mark them up for profiteering.
I recently received my two a 42t & 32t each one under £4 each, both arrived within 14 days.
See pic #18 on the thread below.
Roadrat Alfine 8 with G370 hub build.
As per the title, the build though may take a while as I am quite busy. The tower scaffold has already been up and down twice and will be so a few times more this year and the bees are needing my attention alone without other distractions. The rubbish is building up as well due to the council...www.pedelecs.co.uk
Hi, not sure what you mean by the front chain ring, if it's the one beside the pedals at the motor they are usually much smaller than 44t, mine for example is 11t.
What make and model of bike is it, it might help us to help you.
To answer your question fat rat, yes I was being serious, the user said they were new to eBikes, and didn't say what bike they were referring to hence the reason I asked.
I like to make sure I have the right info before giving advice, but each to their own.
To answer your second question...Yes I have been inside too long
