dead mobility scooter help
6,722
light is flashing 6 times which means it is the brake tried to bypass both ways it and still not working and flashing 6 times any way to get it going again?
6,722
does not matter cant be fixed so going down the scrap yard
3,376
Could 6X flash mean throttle error? Is the throttle not starting from a neutral position, when the power is switched on? Or it could be throttle wiring? Try setting the throttle to neutral while it's on, then switching off, then switch on.
There might be a section in the manual regarding error codes, for whatever mobility scooter that is, somewhere on the internet.
6,722
there is a sensor in the brake and it is dead so no way to bypass it but got another scooter anyway
3,376
You could suddenly have a lot of extra torch batteries?
6,722
it is sla so nope
Andy-Mat
2,214
564
78
Good point! The best batteries around nowadays!
Also, an almost full set of spare parts, just missing the bit that is actually defective!
regards
Andy
