October 28, 20196 yr I picked up a Dawes arc ii 2020 via my employers cycle to work scheme, and as is usual for me, I'm looking to mod it already. I chose this bike as I wanted something I could fold up on the train but also to assist up the hill on the commute home. What I want out of this bike is: Throttle LCD display Bigger battery The bike is limited to 25kph as expected, but what I have noticed is that there is no taper on the assistance. I can ghost pedal on the flat and on the highest assistance level I still reach 25kph. I was expecting less assistance as the speed progressed but that does not seem to be the case. First up will be swapping the standard controller and led display for this: http://www.pswpower.com/ven.php?cargo.2016-3f-3f7c That will cover my itch for throttle and display. Once that is done I will start on getting a higher capacity battery. The current battery fits in the frame, 10s3p, but using pretty rubbish batteries with 2200mah capacity. Totalling 6.6ah I want to get it rebuilt with 3400mah batteries, giving a capacity more in the range of 10.2ah My next post on here will be documenting the existing cabling on the bike, and the arrival of the new parts when they arrive
October 28, 20196 yr before you buy the parts, you should post pictures of the controller's connectors and motor cable connector. As for rebuilding the battery, I don't think it's possible. You can of course replace it with a higher capacity one.
October 28, 20196 yr Author That's exactly the same battery pack as on my bike. I have seen those cases, and filled batteries in Alibaba etc, but I'm not sure I trust ratings and capacity on a Chinese battery. I would rather pay for someone in the UK to swap the cells with higher capacity ones. I have taken a picture of the controller, but I'm on mobile right now so cannot post it. It definitely does not have a throttle cable. The motor wiring is 3 phase plus hall sensor. Motor in question is a mxus xf08
October 28, 20196 yr Author Hmm I'll have to take a look, I have taken the battery case apart, and doesn't seem too difficult for a pro. Quite a bit of space. The cell pack itself is not glued to the case. For now though I want to focus on the controller upgrade. The battery can wait until this is finished
October 28, 20196 yr Ebikebatteries.co.uk in N.London, Jimmy is the man. For a descreet lcd then a kt lcd4 is probably the answer, go to topbikekit for many options to choose from.
October 28, 20196 yr Author Only issue with lcd4 is that I don't think it has all the P/C options available? Vfr400 is going to test in the next day or so and let me know. That topbikekit site, is it trustworthy? The translation is a mess
October 28, 20196 yr Author What's the recommended method of posting pictures on this forum? I have pictures of controller and wiring to post
October 28, 20196 yr Author Wiring. As you can see, no throttle cable. I can see 3 phase, power, display connector, 2 X brake connectors, Pas sensor, and hall sensor
October 28, 20196 yr The sine wave controller you mentioned should work pretty well. You'l have to change the connector on the hall wire, or better still, cut the connectors off and solder the wires. I don't know which 3400 cells you're looking at, but be aware of the current they can supply. I made a 20 cell battery with 20 amp 3000 mAh LG cells in it. It should have been 6Ah, but at only 10 amps ( 5A per cell), its capacity reduced to 5Ah, when tested on a battery tester. Whatever the cells are supposed to be rated at (currentwise) divide it by two. that means a 30 cell battery for your 15 amp controller needs to have cells rated at 10 amps continuous each as a minimum. Jimmy will be able to help you with an appropriate choice of cells, so discuss it with him.
October 28, 20196 yr Author Any idea where i could find the correct connector for the hall sensor to either match the new controller or to match the existing connector coming from the motor? I'd rather be able to unplug the controller in the future without having to unsolder the hall sensor cabling
October 28, 20196 yr You have the 9 pin connector on the end of the motor wire. You don't need connectors at each end.
October 29, 20196 yr Author Right, didn't know there would be a connector closer to the motor as well. Anyway, I've ordered the it kit via pswpower. Paid for tnt shipping and they say it will be 3-5 working days. Now it's just a waiting game
October 29, 20196 yr Right, didn't know there would be a connector closer to the motor as well. Anyway, I've ordered the it kit via pswpower. Paid for tnt shipping and they say it will be 3-5 working days. Now it's just a waiting game Not all bikes have the 9 pin connector near the motor. Have a look to make sure. It'll be about 9 inches from the motor if you have one.
November 7, 20196 yr Author So my new controller and accessories has arrived, but I'm struggling to work out the wiring. There seems to be a bunch of extra connectors I did not expect. Could someone help me identify what wire is what please?
November 7, 20196 yr Starting at the white one at the top. Speed sensor PAS Throttle Brake Brake LCD Hall sensors including motor speed sensor Light switch Horn switch Horn (battery voltage) light (battery voltage)and ground Blue pair cruise - leave disconnected Grey pair EABs - leave disconnected White pair speed limit - leave disconnected and set speed in LCD
November 8, 20196 yr Author I'm home today so thought I'd start on the bike. Fitted the display and throttle on the left bar and then moved onto the controller. And this is where I have hit my first issue. The replacement controller has female plugs whereas the original had male, and vice versa. What my best option here? I was thinking of snipping the correct plug/socket off the old controller and cutting off the wrong one off the new controller and soldering it back inline. Any other better options for me?
November 8, 20196 yr Author We have life! I've spliced in the original hall sensor plug to the new controller, hooked up power, 3 phase, throttle and LCD. Press the power button and the LCD lit up. Pressed the throttle and the wheel turned! Tomorrow now I will swap the plugs on the brake and Pas sensors and we should be good to go after a tidy up of the wiring and configuration via the lcd
November 8, 20196 yr Good show, soldering direct and heat shrinking is a permanent reliable connection to use.
September 4, 20205 yr Hi there I’m new to ebikes and have a very similar bike to this with the same components etc I am looking to add a thumb/twist throttle is this possible to the standard motor at all? If so how?
September 4, 20205 yr Hi there I’m new to ebikes and have a very similar bike to this with the same components etc I am looking to add a thumb/twist throttle is this possible to the standard motor at all? If so how? It doesn't matter what motor you have - they all work the same with the same wires. What's important is the motor controller. Without knowing what bike and controller you have, we can't help.
September 4, 20205 yr It’s a rok model1 I’ve been told it’s the exact same as the Dawes arc2 apart from brakes
