Hi guys, I've introduced myself in the new members area with pictures of the new bike that I've built myself.
Here:
http://www.pedelecs.co.uk/forum/threads/ive-just-finished-building-my-first-trail-ebike-pics.18787/
I initially only fitted the hand throttle to the bike. I also have hydraulic disc brakes so I chose not to fit the electric brake levers with the cut off. I come from motorcycling so I was happy to just be in control of everything myself.
Today however I fitted the pedal assist hardware (a sensor and a disc of magnets on the crank.) Just because I can. The system doesn't have any fancy torque sensors or anything. I wired it in with a switch so that I can turn it on and off.
Here's the switch panel and the side of the bike removed. One switch is to disable the hand throttle, one is for the headlight and the third the pedal assist. The switch panel will be hidden behind a layer of black foam that fits between the two bike side panels, this will help to keep it dry and clean.
My first thoughts of the pedal assist system is that it is both dangerous and inefficient. (I understand that this is bottom of the market stuff and that the switched brake levers would make it function better.)
There is a painfully long delay for the response of the power when pedaling meaning pulling away is hard and then suddenly you're catapulted forward. Also, when stopping pedaling there is a delay which is quite frightening.
I guess it's OK at speed but around town and in traffic it'd be a nightmare!
Maybe as a form of cruise control it makes sense to me but then why not just have a switch?
Here:
