Hi all
My first post - pleasure to meet you all! I've just acquired a Dahon Helios SL which I'm very excited about; however I was really on the market for a light electric foldable and so I've taken a punt in the hopes that I can covert this super light bike into a super light electric bike. I know a bit about bikes (little compared to most on this forum) but know next to nothing about conversions. I was wondering if any of you could think, off the top of your heads, of a front wheel kit that might be compatible with the Helios SL? I haven't taken delivery of the bike yet but I'm assuming it will have a <80mm distance between the front forks and so know that I need to be careful about what I choose.
Budget is not really an issue - weight and quality is. I won't be doing more than 6 miles per journey, all flat terrain and I weigh about 12.5st. I'm fairly technical so feel I can read my way through this but if people think the contrary, I'd be willing to pay someone with the expertise to make sure it all goes to plan.
Any advice is appreciated. Looking forward to getting stuck in! Again, pleasure to be a member of the forum.
Cheers
Specs of bike:
SPEEDS: 8
GEAR INCHES 31" - 91"
DISTANCE: SEAT POST TO HANDLEBAR 670 mm (26.4")
DISTANCE: SADDLE TO PEDAL Min. 710 mm (28"); Max. 950 mm (37.6")
FOLDED SIZE 28 x 56 x 81 cm (11" x 22" x 33")
WEIGHT 7.6 kg. (16.7 lbs) base model w/o options and pedals
FOLDING TIME 15 seconds
SUGGESTED RIDER HEIGHT 142 cm - 193 cm (4'8" - 6'4")
MAX RIDER WEIGHT 105 kg. (230 lbs.)
FRAME Y Series, 7005 double-butted aluminum alloy, custom-drawn Sonus tubing, forged Lattice hinge, patented Re-Bar™, EmBed, ViseGrip technology, replaceable derailleur hanger
FORK Dahon SlipStream™, Puro™ U6 aluminum alloy, integrated, Fusion technology
STEERING COLUMN Radius ProLite, patented Fusion™ design, forged aluminum, patented InSide™ lock
HANDLEBAR Dahon CarbonLite riser, custom
HEADSET Dahon Fusion XP, Zero stack, machined aluminum cups, ACB cartridge bearings, sealed
GRIPS ProLite foam
SADDLE SDG BelAir FX, I-Flex design
SEAT POST SDG I-Beam Pro, SuperOversize, 2014 aluminum, forged clamp
BRAKES Kinetix UltraLite, forged aluminum V-brakes, micro bolts, front Flex stainless noodle, stainless anchor bolt
BRAKE LEVER Avid FR5
CABLES AND HOUSING LiveWire™ K, Kevlar SIS housing, slick cable, LubeTube oil port
FRONT WHEEL Rolf® Prima Accel™ - 390 grams
REAR WHEEL Rolf® Prima Accel™ - 640 grams
TIRES Dahon Special Edition Schwalbe Stelvio, Mango/Black, 28-406, 120 psi, foldable Kevlar bead, DualCompound Silica casing, RaceGuard anti-puncture protection
SHIFTERS SRAM X.7, 8 spd.
DERAILLEUR SRAM X.7, Dahon custom edition
CASSETTE SRAM, 11-32, 8 spd.
BOTTOM BRACKET American Classic UltraLight
CRANKSET Truvativ Elita, ISIS, forged 6061-T6 aluminum, 6061-AL chainring, alloy chainguard w/ CNC finish
CHAIN KMC Z82
PEDALS MKS Promenade, QR
CLIP SYSTEM Magnetix™ system
TOUCH UP PAINT Yes
ACCESSORY Reflective pants clip
Cheers
Specs of bike:
SPEEDS: 8
GRIPS ProLite foam
CHAIN KMC Z82
TOUCH UP PAINT Yes
