Looking forward to David from Wisper keeping us updated on timescales for Daahub hitting the shops and any developments.
David?
Thanks.
Hi Schoe, thanks for the invitation!
The unit we presented at Eurobike was the final pre-production prototype. It has taken nearly 9 months longer than we first planned two years ago when the concept was discussed. It still needs some tidying and small tweaks but we now have orders for several hundred units for delivery in February of 2011.
The system has been designed to go off road so getting the dock (battery mount/controller case) and the battery case strong and robust enough to cope with 1000's of miles of mountain biking and BMXing has been a challenge. The clamp on the dock now has silicone shims that have added suspension between the battery/dock and the bike this has worked wonders. We have also beefed up the casing and instead of the top and base of the battery box being self tapped they are now bolted together using inserted brass threads and hex bolts all resulting in a very tough construction.
For extreem off road use, we have developed DaaBag, a high end Camel Back style rucksack with water bladder and a special home for the battery. The battery is connected to the bike through the Dock and amazingly is hardly noticeable when riding. DaaBag will be ready for our launch in the UK shops in February and will cost about £100.00 extra.
All the best
David
