I'm an owner of a CycloTricity Stealth 48V/1000W E-bike that has been used for 1748 km/1086 miles without any motor or battery problem. After last charging it simply does not work No warranty so I have to fix it on my own. I'm very thankful for any help to locate the source of the issue (Is it battery, motor, controller or something else?)
Issue described (with video):
Bike can be turned on without problem on the LCD controller. Whenever motor power is triggered regardless if by the assistance-button or by pedals, the motor only runs for a maximum of 1 second or less and LCD goes black and bike acts if its turned off. After this has happened I can turn the bike on again from the LCD controller and replay the same scenario. See the video I recorded for a demonstration of issue:
I'm not good with electronics but still was able to measure the output connector on the battery with a multimeter to about 54V. What I think is suspicious is that if I turn battery switch to "off" my multimeter shows 51V on the battery output connector. Should it not be 0V if turned off?
The battery is Cyclotricity of type 48V/16Ah with USB output, On/Off switch, 4-LED Battery status indicator with button, and an output connector.
Many thanks in advance for any help in trouble shooting this!
