I have ordered the Cyclotricity 250w kit, should be here Sat or Mon, Ebikes Direct charged me an extra £21 cos I`m in the North east of Scotland, not happy, but HeyHo, I downloaded the Installation manual on how to fit it to my Carrera (Typical broken Chinese) and a bit vauge, well to me anyway , I have a sealed bottom bracket so it says you have to fit the PAS sensor to inside of the crankset on the right and not the LHS crank, instruction below, hopefully will be clearer when I`m fitting it.
1 Insert the PAS sensor inside the bottom bracket, insert it from
the left end to the right end, the right end will act as a stopper.
2 Install the bottom bracket onto the crank (by turning it anti
clock-wise at the chain-wheel side and clockwise at the left pedal
arm). Make sure the sensor device is facing outwards.
3 Once the bottom bracket is firmly installed, insert the black PAS
magnet disc onto the right shaft.
4 Make sure the arrows on disc are clock-wise (the direction of
pedalling).
5 Install the pedal arm back and tighten with a wrench.
Also does this bit below just mean you have to make sure your wheel is secure, any advice greatly appreciated.
Exceptions to limited Warranty
“Spin Out” – Spinning out the axles inside of your dropouts – We
are unable to be there when the kit is installed so it is up to you to
understand the high torque involved at the dropouts and install
them correctly.
If your dropouts are not correctly suited to fit the axle then you
should not install the kit on those forks. Get new forks, file the
forks to the axle fit “flush” or contact your dealership to return the
kit. We will not refund or replace a motor that has been “spun
out”.
