Cyclotricity e bike kit
scott gaza
162
24
scone
Hi madge, You can use a KT lcd3 with Juliet/higo connectors but it won't have the unlock feature also you will need a good celled battery to power your direct drive hub.
Reactions: madge45
3,994
Tell us what you want to achieve from your ebike kit so that we can advise you of the best solution.
8,773
Cyclotricity use a customer custom option which uses different software for their kits to enable the twin power/unlock mode, if you want to still access both power modes then you have little choice but to buy from them.
A commonly available LCD3 will work but you won't be able to unlock/access the 1kw power mode. It is why they charge more, a custom setting they have paid for and is not available else where.
Reactions: madge45
