Cyclotricity/Carrera
  • Start date
I acquired a Cyclotricity Stealth with a damaged frame. it had done 900 miles before it got damaged. I bought a Carrera frame from Ebay along with a new headset and swapped all the parts from the Cyclotricity to the Carrera.
I tested the battery with my battery tester and it went for 156 minutes at 5 amps, which is exactly 13 Ah.
The only defect is that the level numbers in the LCD don't always show correctly. I wanted to show photos, but as soon as I got the camera out they started behaving. It's only that some segments don't show, presumably because of bad contact. it doesn't affect the function of the bike in any way.
£300 if anybody wants to come and get it before it goes on Ebay next weekend.
18" frame, should fit most people. I've done about 40 miles on it since I built it. It works perfectly.
20170320_154045.jpg 20170320_154145.jpg 20170320_154107.jpg 20170320_154151.jpg
Does this derestrict at all @d8veh ?
Yes. You can set the speed limit in the LCD. It assists to about 20 mph when de-restricted, but the power ramps down from about 15 mph, so de-restriction doesn't give a massive benefit. A lighter rider might get more advantage from it.
LeighPing
2,547
1,945
The Red Ditch
PM sent.
