Cycle Analyst Shunt cable available in UK?
Hi, Before I send my order overseas, can anyone advise of somewhere in the UK (or even Europe) that I can purchase a shunt cable for a Cycle Analyst 2.3 please?
Thanks you kindly.
Enjoy the sunshine and happy riding!
Cheers
Darren
The Cycle Analyst has a setting for the actual shunt resistance (Rshunt). You only need to be within 10%. so using a 5cm piece of 14g wire will get you close enough. You can only calibrate it if you have a known current.
If your controller has the max current written on it, that's normally fairly accurate, so you can connect everything up with the Rshunt value set to .005, which I think is the default, then power up your bike with the wheel off the ground and apply the brake to slow it right down. The CA should show the current equal to the controller's max. You can make small adjustments to Rshunt to get it right. Don't hold it slow for too long because things heat up quickly.
Don't go too thin on the three thin wires from the shunt. 22g is probably about right.
I just checked. The CA shunt is 0.001 ohms, so you need to change the default Rshunt. I made a mistake above. It should say 0.0001 per cm so 5cm =.005 Ohms. You could use 10cm if you wanted for 0.001, but no point in using more wire than you need. In fact, you don't need to do anything special, you can just solder the three wires to the battery wires with the sense wire 10cm along from the ground wire.
