Cheapo battery meter lashup
Hi all i wonder if anyone has the cycle analyst meter fitted to their e-bike i am looking at a more accurate way to measure how much power i have left in the battery as i ride over 30 miles a day the led meters are not accurate. How easy is the stand alone model to fit? (please bear in mind what i know about electronics you can fit on a postage stamp ! )any advise/info would be appreciated.
The CA sounds nice, but I have been exploring a really cheap way of measuring the amount left in the battery by measuring its voltage with a very cheap digital multimeter from Maplin (Thanks again to
NRG's post for the heads up on this). The UT30B is on sale at £7.99 (reduced from £14) at Maplin until 9 August.
The basic problem is that the typical 3 LED handle bar indicator gives a much too coarse indication. By measuring the exact voltage of the battery we have much more precise information. Of course to make use of the voltage readings one has to determine what voltages correspond to the fully charge state and the fully discharged state. Here is the graph I made during one charge.
This battery was not completely discharged before I started this charge up: there was probably about 15% of charge left in the battery when I put it on charge.
Here you see the meter lashed to my wooden instrument bench which I have installed on my handle bars. The other instruments (right to left) are Garmin GPS and Digital Thermometer. The bundle of white wire leads down to the battery terminals.
This lash up is just an experiment to demonstrate it and get experience. The mounting arrangements will need tidying up, but I have already been 20 miles incuding rough ground as I watch the battery be run down. You can see I am at 25.2V at present. there is only 1 LED out of 5 showing on the battery, and just 1 out of 3 on the handle bar indicator unit. I am expecting the battery cut out will occur with just a bit more voltage drop, so I am planning an early morning ride tomorrow to measure that voltage.
