The Bosch CX system comes in for a hard time on here, so I thought that I would offer a different perspective, based on my experience.
My only previous (or subsequent) ride on an ebike was on an old Giant Twist that my mother uses, it is slow and heavy but was quite capable at climbing the hill that my house sits on. I was at the time using an old Trek 1.5 roadbike for half my one-way commute of 26km, driving half way in moderate traffic and parking prior to cycling the remaining congested 13km in Dublin. My aim was to complete the entire journey by bike, something that was not doable for me on the roadbike as a permanent solution.
Driving, my commute was taking 45min in the morning (leaving early) and my return trip time varied from 75-120min in the evening. As a result, I was considering moving job as I have young children and I was not getting to see them in the evenings. The commute is mostly flat and 50% on an off road tarmac cyclepath, the remainder is on street with some segregated cycle lanes. I live half way up a steep hill so that was to be considered and the route is coastal with little in the way of wind protection.
I bought my Cube Reaction Hybrid HPA Pro 500 2017 late on in 2017 from Chainreaction. It was chosen as it was the cheapest ebike with a 500wh battery that I could find within the remit of the Irish cycle to work scheme. Chainreaction had good deals at the time, possibly due to the remaining restrictions on Pedelecs in Northern Ireland, the bike cost ~1950eur. Spec (abbreviated) was as follows:
Fork: SR Suntour XCR32 RL-R coil, 100mm, remote lockout
Rear Derailleur: Shimano Deore RD-M610-SGS, 10-speed
Shifters: Shimano Deore SL-M610, Rapidfire-Plus
Brake System: Shimano BR-M315, hydraulic disc brake (180/180)
Crankset: FSA CK-745, 15T
Cassette: Shimano CS-HG50, 11-36T
Front Tyre: Schwalbe Tough Tom, active, 2.25
Rear Tyre: Schwalbe Rapid Rob, active, 2.25
Engine: Bosch drive unit performance CX (75Nm) cruise (250Watt)
Battery: Bosch PowerPack 500
Display: Bosch Purion
The bike arrived well packaged but with an EU plug on the charger and no pedals which were listed on chainreaction. I just used a 2-3pin plug adapter. I put the bike together in about 5min, put some SPD clip pedals on it, charged the battery and cycled to work the next morning. To be honest I was disappointed – the bike would fly up to the 25kmh cutoff and then stop. I spent most of the time over the limit but still being passed out by roadbikes on the busy cycle tracks. I wasn’t using much of the battery either with it lasting 2 days on my commute, however the bike would easily climb the steep hill that I live on so I knew that the bike was well powered. Otherwise the bike was very comfortable (bar the saddle but that’s due to personal choice) and very (very) stable on the road. It had excellent brakes compared to the roadbike, which I welcomed in traffic.
For me the speed limit had to change so I bought a Speedbox 2 delimiter from ebiketuning, note that the extra connectors that they recommend are not required. I also bought an isis crank puller and the Ebikespider spanner to remove the bosch chainring nut. Fitting was easy.
Without getting into the semantics here the removal of the limiter was a total relief, I chuckled all the way to work and arrived in record time, under an hour. However, this was to the detriment of the battery range which used 3.5 of the 5 bars on the 26km journey, luckily I had packed the charger.
Upgrades / Purchases / Modifications:
Marathon MTB tyres to replace the crap OE Schwalbe tyres following a sidewall failure in the rear one – no punctures in 8k km.
A spare charger for work
I’ve used Topeak universal frame mounts to fit a bottle cage and a fitting for a Abus lock.
Soon after delimiting I upped the front chainring size to an 18T. This is good for reasonable cadence up to 55kmh.
After fitting a WTB saddle, which was okay but not totally suitable, I went for a brooks B17 saddle which, once broken in, is fantastic, I’ll never buy a different saddle.
A chain washer which works great.
I got a service kit (seal kit and grease) for the motor. I have replaced the seal twice following scare stories on here.
I had the SPD clips on it but forgot to unclip in the driveway and fell over and busted my knee, since swapped for flats.
I’ve used USB lights, the best being a cheapo one bought in Aldi/Lidl.
A Joovuu camera following a crash from a left hooking van.
A Zefal front MTB mudguard and a muddyfox rear one.
Planned Upgrades:
I have obtained Light & Motion Nip & Tuck ebike lights and am waiting on the correct connectors to wire into the bikes circuit. I will do up a review on this following fitting.
New pedals and grips
Maybe panniers, not sure yet, the Osprey backpack has been excellent but panniers may make the commute a little more comfortable.
Gotchas:
Sidewall failure of a Smart Sam OE tyre on the way to work. Chainreaction were excellent and sent me an upgraded MTB tyre but in the meantime, I replaced with the Marathon MTB tyres which are rated for Speed-pedelecs.
Crank bolt fell out again on the way to work, probably because I didn’t torque the bolt to the correct setting following a service. Could not find the bolt so I had to walk the bike to the nearest shop which thankfully had a spare.
Forgetting to change the battery at night or in work has left me getting the train home on a couple of occasions.
Cons:
Not much to be fair, I now realise that crank drives require a bit of driveline maintenance. I replace the lot and seem to get 2.5 to 3k km at a time with lax chain cleaning. I enjoy doing my own maintenance and this does not bother me, I buy the parts on bike-discount.com ahead of time for about 50euro.
Upon reflection I would probably get a lower profile bike with less windage and possibly less weight as I never take the bike offroad, I really like the look of the haibike Xduro. This would allow for a higher cruising speed theoretically, but I generally cruise as 40-45kmh so it’s not like I actually need more speed.
The stock grips are a little uncomfortable, but I haven’t replaced them yet.
The battery lock is a bit fiddly.
The speedo isn’t accurate, seems to overread by 2-3kph
CX motor is noisy, a consideration but I don’t care what other cyclists think of ebikes.
The Cube satin paint finish isn’t very durable, seems to mark easily but this bike is a hack and it gets no cleaning / love / anything really.
The whole CX motor seal which lets in water thing scared me into performing my own motor grease and seal schedule. Despite this there are spots of rust on the outer bearing. Like I said I do not go offroad so this issue will hopefully not manifest for me.
Pro’s:
8000km this year and nothing has gone wrong. Had motor checked after an RTA with a Van and the Bosch guy said it was fine. I haven’t even needed to index the gears. I give this bike nothing but abuse, its permanently delimited and is always on Turbo and it is my only form of transport and has so far proven to be 100% reliable – for a bike I feel it has been exceptional considering the only love it gets is a new drivetrain every now and again and a chain wash. I don’t even clean it. Looking at other reviews with similar distance commutes, I am not sure that this is common across different drive systems?
Using the bike has meant that I have been able to remain in my current job without going insane in traffic, I get to see my family more in the evening and I am getting exercise every day. It’s been so effective that I have given up my car and we now have one car for the household. Therefore, the bike has already more than paid for itself (= free bike + extra beer money in my book).
Caveats wrt. delimiting:
Delimiting the bike is illegal, I am not going to debate that, but I feel that it has made the me safer in some respects. Like being able to maintain speed in traffic, I can take primary position on the road preventing passes, and therefore reducing close passes. Driver behaviour in Ireland is poor towards cyclists and I feel that the bikes speed is a defence against this.
There is a huge responsibility in riding a delimited bike. If you are in an accident it will likely be serious. Humility is key and complete deference to other cyclists and to pedestrians is required in my opinion. Also, drivers simply do not expect you to be moving as quickly as you do so I try to make allowances for them, no banging on bonnets when they cut you up, they probably simply did not expect you to be there.
Conclusions:
Despite some of the drawbacks of the Bosch system I feel that I cannot ignore the complete reliability I have experienced. Also, I feel that the performance of the system is top notch. Upon reflection my choice of an eMTB was probably incorrect but it has still done the job and more than met my expectations. Also, I am unsure if a less sturdily built bike would have taken the punishment that’s been inflicted upon it. Like I have said I have not experienced a decent hub drive bike but, for me, the crank drive Bosch will take some beating.
Planned Upgrades:
Gotchas:
Cons:
Pro’s:
Conclusions:
