Exactly my experience with both sstems as well.As an opinion, crank-drive is better for sporty riding. Hub-motor is better for commuting and touring.
You could set a lower PAS setting. That's like saying, "There's a problem with throttles. If you leave it fully on, you'll go maximum speed everywhere".As I live in very hilly terrain I prefer the crank drives for their climbing ability.
There is one factor to take into account that I never hear mentioned, on a PAS (non torque) operated hub when you pedal the motor will accelerate upto its max speed if left in its top PAS setting which means you basically do zero or 25 kph short of tapping the brakes or consantly changing the PAS setting.
On a Crank drive with the same PAS, low may get a 8 kph top speed and that will step up with the gears, this is very handy in traffic as when I come up behind a slow car I just shift down to mattch speed and the same as they accelerate, so with a crank drive you dont have to alter PAS at all, I ride in highest assist at all times and adjust speed and power use with the gears.
Obviously IF you have a throttle you can over ride the PAS.
Basically having ridden both I find the crank drive more like riding an unassisted bike.
That's a great effort, but I think there's a few hub-motored bikes around that would annihilate that time:Crank drive lets you beat the Pro riders too
It applies to the most common PAS type at the moment, adjusting PAS constantly is at best arkward and requires taking your eyes of the road and with some bikes one hand off the handle bar, not ideal in traffic.You could set a lower PAS setting. That's like saying, "There's a problem with throttles. If you leave it fully on, you'll go maximum speed everywhere".
Anyway, these things are nothing to do with motor characteristics. They're the control system that can apply to either type of drive system
http://www.pedelecs.co.uk/forum/threads/custom-build-4080-18-fet-56mph.16989/#post-209187
I've not heard that one before.I thought most bikes crank-drive or hub motors have a panel where you adjust the power.It applies to the most common PAS type at the moment, adjusting PAS constantly is at best arkward and requires taking your eyes of the road and with some bikes one hand off the handle bar, not ideal in traffic.
http://www.strava.com/segments/4109724?filter=overallThat's a great effort, but I think there's a few hub-motored bikes around that would annihilate that time
Dan ?
The same with this Bosch one:If you are talking about taking the hand off the bars, the Ezee I tested recently had the PAS panel in the center of the handle bars
