Crank arm hitting the rear stay
cwah
3,048
179
www.whatonlondon.co.uk
selrahc1992
559
218
Hello,
My bike crank worned out and I decided to buy a new one from Amazon:
http://www.amazon.co.uk/Cotterless-Steel-Crank-170MM-Black/dp/B0044RGEHS/ref=sr_1_2?ie=UTF8&qid=1434220493&sr=8-2&keywords=bike+left+crank
Once installed, I realised it touched the rear stay:
I initially decided to install it a bit more loose, but after a fall it resulted in a bent I think and now it is always touching it...
What's the best approach for me? the arm is steel, maybe I can hammer it right?
Just a thought,but could you have installedvitcwrong way round? I've done that before. Your crank end seems to protrude a lot and there's a distinct curve to the arm which may swing out other way round.
SRS
848
349
South Coast
If it did not fit when new the you need one with more offset.
You cannot install loose as the thing sits on a taper and has to be fully home.
Bending it is not the answer either as the pedal axle would then be p*ssed.
Get to the bike shop and they'll sell you one that will fit.
cwah
3,048
179
I had a small hope that this could be the case and tried it but it doesn't seem to be the case :/
Before:
After:
And I can't put it the wrong way around on the pedal side:
C
Cyclezee
Hi cwah,
How exactly was your old crank arm worn out? If fitted correctly there is nothing that can wear.
The new one you fitted is the right way round, but clearly not the same pattern as the old one which did not hit the stay.
cwah
3,048
179
The thing is it was working well before I felt. So it must have been bent somewhere, somehow. But I can't see where
cwah
3,048
179
Hi cwah,
The thread to fit the pedal was worn. So pedal was getting loose as I was cycling and nothing I can do to tighten it up as thread was gone.
No other choice than buying a new one :(
As said, I think it may have been bent from my fall because it was working before, although I didn't tighten it completely..
C
Cyclezee
That would be it then, the crank arm must have bent when it fell.
Sorry, but you need a new crank arm as you would need to be Hercules to straighten the bent one.
cwah
3,048
179
What about hammer it straight? Maybe that could be done?
trex
7,703
2,671
you can try but if you don't get it right, it'll make your pedal wonky.
cwah
3,048
179
It's closer to 1cm than 1 mm... my main concern is that I'm not sure if the problem is with the crank arm, or if it's with the bottom bracket.
If I change the arm and I have the same issue it means the bottom bracket needs changing...
But trying to bent it back may cost me nothing and just fix it?
trex
7,703
2,671
Reactions: cwah
It's aluminium, not steel. You can bend it easily in a vice, but you have to heat it up to red hot first. You don't have to bend it while it's hot. When you try and bend it (after heating), it will move a little bit, then stop. You then have to heat it up to red hot again and you can bend it a bit more. Don't bend it more than you need to otherwise the pedal axle will be at the wrong angle, which will make the pedal feel wobbly when you pedal.
cwah
3,048
179
cwah
3,048
179
On amazon it says steel. I should test it with a magnet.
I only have a small soldering torch:
http://www.amazon.co.uk/gp/aw/d/B004CLA01W/ref=mp_s_a_1_8?qid=1434227265&sr=8-8&pi=AC_SX110_SY165&keywords=soldering+torch&dpPl=1&dpID=41xXDxEx0HL&ref=plSrch
Because I have such limited space I can't afford to get bigger tools.
Would that be enough to make it red hot?
selrahc1992
559
218
This thread is beginning to give "touching the void" a run for it's money, if I were in your shoes I'd just buy a new bb and crankarms on fleabay,its dirtcheap and easy to install. I'm not an engineer but the idea of jumping around on an ally crank i ve bent and heated would give me the heebyjeebies
Reactions: cwah
Kuorider
379
195
Cwah, Please stop wasting your money and time ,get yourself and your bike to a proper bike shop and the man there will fix this in no time. Your talents lie elsewhere. Effort without knowledge is of no avail.
Reactions: One_Box
