Coyote connect
Rikunj
Feb 24, 2021
Hi there I’m new here
Could any one help me I have coyote connect 24v 240bike it’s power on but after one pedal power switch off I che ke all connection in battery to controller is ok also it’s blowing fuse 2 time so any suggestions how to short this out
3,994
Check the motor connection. If there's a connectot about 10" from the axle, make sure it's oushed in all the way to the marked line, not just in tight. If that doesn't fix it, you have to look at the other end of the motor cable that's inside the compartment at the front of the battery. Look in there at the connectors to make sure that they're all tight.
There are other causes, but you need a meter to do some tests to find out more. How did the problem start? That will give a clue to what's wrong.
Rikunj
Feb 24, 2021
Hi there thank you for replaying me
I check that all motor connection fi’s ok and they all are tight also I have multi meter so plz guid me how to check problem started 2 week ago I thought I only day I ride the bike in snow to come home from work after that problem started
3,994
The first test is for the mosfets in the controller. Disconnect the three thick motor wires (blue, green and yellow) and the two thick battery wires (red and black). Set the meter to measure KOhms resistance. Measure between the red battery wire and each of the three motor wires. Repeat the three measurements using the black battery wire
Each group of three readings should be the same as each other, but the two groups might be a bit different. Sometimes, the result will continually climb on the meter. In that case, take the initial reading as best you can. Tell is the results.
