Hi All
Sorry, I am out of touch with bicycles for years so I am not up to speed on adjustments etc.
I got my rear wheel onto my Carrara Kraken MTB this evening, 9 speed 11t DNP freewheel fits too without much stretching of the rear forks. I had to put two of the washers that came with the conversion inside the freewheel on top of the spacer to space the forks enough to stop the chain fouling them. I could reduce the last washer by 3mm or so which I will do.
I adjusted the derailleur stops to stop the chain at the 11t cog. I have about six sprokets available which is loads.
I noticed that the rear wheel is about 8mm off centre due to the thicker 9 speed freewheel. I can get that to about 5mm by replacing the aforementioned washer with a thinner one.
Is was wondering if this 5mm off center is a problem maybe with tracking or something?
The other question is regarding the disc brake. I cannot find a disc to fit my 48mm adaptor so I thought I would adapt an ISO disc or make a new one using a 2mm steel disc.
Does anyone know if its possible to just make one or are they made from some exotic material.
Charlie
Charlie
