I've been running my BBSHD powered fat bike for 300 miles. and all of a sudden it developed a metal on metal sound, and a slight vibration on the drive side of the motor, so I done the usual and checked with WWW land, and discovered that a lack of, or incorrect grease on the secondary drive, which from the way it feals/sounds, sounded about right. So I took of the cover to be shocked on how little grease there actually was on the drive gear, and what little there is has just been pushed to the edge not coming into anything of any purpose.
My problem comes from what grease to use, some say moly grease others say don't use moly as it can get into the primary and degrade the nylon gear. But others say either Mobile28, or Aeroshell 22. What do people here recommend, and I need to use my bike daily for work, and the only grease I've got to hand is white lithium grease, would I be OK to use this for now ? I need to travel about 60 miles, in total, depending on how long delivery of the correct grease takes to arrive. I'm thinking some grease is better than none, and the bulk of the temp solution can always be removed when the correct is applied. Cheers guys.
