New to the forums- I've browsed the old threads and someone claimed that the Currie I-Zip (Comfort bike model with outboard chain-driven gear motor) rear wheel was easy to remove as a standard hub.. I think they must have been talking about some other model (as they mention that there's a quick-release, which does not exist on my bike), or I'm just not getting it..
Can someone please explain the proper way to remove the rear wheel on a current-model I-Zip that makes it that easy?? I recently had to remove the wheel to repair a flat and I found it incredibly difficult..
With this model of bike, removing the hub nuts does not result in the wheel just dropping out because the electric motor bracket holds the wheel up.. Again, there's no "quick release" and this bracket seems to be (permanently?) attached to the hub bolt with some sort of sliding nut arrangement, so even after removing the adjuster/tensioner, it wouldn't come off and I ended up having to unbolt the motor from the bracket, free the motor drive chain and then take the wheel plus the motor bracket off as an assembly, which was not a fast nor pleasant experience.. Likewise, re-assembly was a pain- put the wheel back in, put the chains back on, line up the motor bracket and re-attach to the frame, then bolt the motor back in and re-tension everything..
