I was looking at the possibility of converting my existing bike using the alienocean kit or similar. However, I have read around that you should not mount front wheels with motors if the forks are made of cast aluminium. The way to check if the fork is aluminium is by simply using a magnet - if it does not stick then it's aluminium. My bike "failed" this test - the magnet did not stick. The fork I have is branded as an NRX 6500 and the specification can be found here:
http://www.srsuntour-cycling.com/SID=side878fef6e37963a2719bcbf63e422/index.php?screen=sh.detail&tnid=105
I cannot find any information about the composition of the fork so would like to confirm if the fork is compatible with a motor.
I would value other's opinions on if this fork would be safe to use with an electric motor.
Thanks in advance.
Mike
Thanks in advance.
Mike
