UA17,
Looking at the kit linked I assume its a front hub with a disk brake fitting ?
If so things don't look promising
Have a look at your front forks and if you can remove the wheel and/or try and measure the distance between the forks. I suspect it will be around 75mm wide. To spread your forks to 100mm will probably be too risky depending on what they are made of.
In addition a 500W motor is a little over powered for a small folder and would also need some kind of strengthening (a torque arm) to make it safe and not spin out the fork dropouts under full power.
I would recommend you get a smaller kit. Something like this
Electric bike kit for 20" folding bikes 36v 250w without battery 80mm narrow hub | eBay
Whilst 24V kits are cheaper they also require larger wiring as they require more current for the same power at 24V. Again I recommend a 36v kit.
email me on jerrysimonsimon at hotmail dot com if you want to chat more off line for options. Most of the work I do is for friends and family and I don't really charge for labor just for parts. For me its just a hobby.
PS looking at the bike spec the forks are steel.
http://www.jejamescycles.co.uk/raleigh-access-folding-bike-id78303.html
That said I would not really want to spread them out from 75-100mm to take the motor. In practice they would probably need to be spread to about 115mm because they will spring back. As I said perhaps measure them and let me know how wide the spacing is ?
Jerry
