Hi All,
Been reading the forum for the last month or so trying to gather up as much info on this as I can and have decided to register as I am now looking to purchase the parts required to build my e-bike.
I haven't purchased a bike yet so was looking to get a secondhand geared alu framed mountain bike (£100-150?) with suspension and then fit a kit to this. To be honest I have no idea if I need to get a specific type of bike or would what I have suggested be suitable or what must it have to do a conversion?
I weigh 80kg approx and was looking at purchasing a 48v 1000w rear wheeled kit and fitting a LifePO4 battery to this with a BMS. Im looking to use it mon-fri commute to work, 9/10 miles with some up/down hills along the way. Trying to get something built for the £600-700 mark
The kit I am looking at is
http://www.ebay.co.uk/itm/190918732542?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The battery I am looking at is
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=181440457652
I would then build some kind of case and mount to the frame. (any suggestions welcome)
From what I have read a 15ah should allow me to get to work, charge it then get back home (correct me if im wrong)
A few questions I have:
Does the bike/battery/kit I have suggested look ok and would it suit what I need it for (would the battery cover the miles I need it to do)
What else do I need other than what I have listed
Is there any other similar spec kits anyone knows of that is cheaper
Is this easy enough to build, I have basic mechanical knowledge
BMS - I cant see one in the battery pic, is this just a monitoring system to show how the cells are and I just watch this and make sure they are equally balanced.
Any help is appreciated and thanks in advance.
Ray
Ray
