Controllers to buy
8,615
KT with lcd.
Reactions: esuark
8,615
Buy form Topbike kit or on AliExpress, expect to do carry out some minoe wiring if the connectors don't match or the wire sequence is different.
All quite east to do by direct soldering or using electrical connectors.
Reactions: UrbanPuma
UrbanPuma
675
43
Ok, thank you
WheezyRider
1,690
938
If you are going to buy a new controller, I suggest getting the Julet cable from the same supplier with it. There are often slight differences between different "Julet" connectors which means they don't always fit nicely together. Another thing to bear in mind is that some controller to LCD connectors are 8 pin and some are 9 pin. The extra pin is for an LED front lamp. The controller might be 8 pin and the cable you have might be 9 pin and if you force the two together, it will not end well :)
UrbanPuma
675
43
Ok, I'd
Good to know. Thanks for this extra info WheezyRider
