You gotta love those Raleigh Twenties.It's easy enough to make brackets out of a bit of aluminium strip. All you need is a pair of pliers to bend the ends and a drill to make two holes for the screws. That's how I fixed a standard box to this one:
After i converted it, the owner said he wanted it to look nice, so i made it like this:
I'd use a fat black ziptie and some rubber e.g. inner tube between frame and box to stop it slipping. It's cheap, there's nothing to make and it'll show less than alu strips.
You can get strip metal pipe clamps the shape of your originals, with optional rubber sleeves, but the bends only hold a light tension so they tend to slip.
Look on ebay for saddle clips , plastic, copper, steel . One can select material and size to suit ones needs.
You go by the size of the tube in the frame. Get some cardboard and cut a slot in it about the same size as the frame tube. Put it onto the tube to check it's the same size. Keep repeating until you get it right, then measure the width in the slot to get the tube size.Yeah that would be even better, as I had 2 clips like this before, didnt know they was called saddle clips, but wont get plastic as mine both cracked, metal would be better and stronger or steel ones. But dont know what size my old plastic ones are, which I posted images of in post 84 above I think they maybe about 3 1/2mm its size of seat post I need
My old plastic saddle clips in my post 84 would you say they same size as you posted in linkYou go by the size of the tube in the frame. Get some cardboard and cut a slot in it about the same size as the frame tube. Put it onto the tube to check it's the same size. Keep repeating until you get it right, then measure the width in the slot to get the tube size.
32mm is a common size for a seat tube. If you don't want to make your own brackets with about 10 minutes work, you can buy ready-made ones. If yours isn't 32mm, you can see other sizes further down the page:
You have to measure the tube, like I explained, or you can measure the inside diameter of your clamps with a ruler or tape measure. I think they should be 32mm, but best to check.My old plastic saddle clips in my post 84 would you say they same size as you posted in link
I am not very good at measuring things, but it seems the gap for seat post is 35mm, 1st imageYou have to measure the tube, like I explained, or you can measure the inside diameter of your clamps with a ruler or tape measure. I think they should be 32mm, but best to check.
Ok many thanks for the info will go ahead and order some. It’s most appreciated thank you32mm is virtually there, you will probably have some gaps between the clips and box when secured and may even need slightly longer screws too (dont think you will tho)
when re-purposing pipe clips your kinda limited to the sizes of the original pipes intended for the clips to be used with.. and slightly smaller is when optimum sizes are unavailable is better than slightly too big imho
edit I doubt any persuasion of the smaller clips will be necessary, the screws when tightened will pull the clip into shape, if not a few taps with a hammer will open up (widen) the clip if needed
