control wireing of kalkhoff
we is white
ge is yellow
br is brown
ro is re
gr is green
With the battery switched on, measure the voltages of each wire to ground. The one with battery voltage will be ro.
Don't let any of those wires touch each other.
yogiellis
11
65
jersey
Thanks so the other wire will be gn , thanks very much for your help on this
matter and have a great weekend
It looks like gr in the photo next to ro!
Gn is green (grun).
yogiellis
11
65
jersey
Gn is green (grun).
Sorry did not read properly , yes I have we,br,gn,ge,gr,ro = 6, but I only have 5 wires brown ,white ,yellow,grey , pink . Thanks again for helping me on this
Hmm! That's weird because all the pads look like they've had a wire on them. Starting from the outside end:
White
Brown
Green
Yellow
Grey
Red
So you should be able to figure out which wire is missing, then you have to figure out what's happened to it. According to what you wrote, it would be green that's missing, but I can see a green in the photo! Has the missing one snapped off where that cable-tie is?
yogiellis
11
65
jersey
Thanks the last wire is pink , not red , I think that I only need 5 wires , battery x2 , lights x2 (lights & power ) 1 wire is a pas signal wire , also checked wires there is only 5 wires , not to sure , so do you think by putting a test on wires will help with it . Thanks again for your help
Related Articles
