Any update about this controller?
Pat
I'm afraid there's nothing further I can add Pat.
Neither the originally supplied controller nor the identical replacement, both sent by
Conhismotor, has ever worked.
Dave very kindly tested the original for me, but he found exactly the same problem, where it does not spin a motor, though the LCD panel works correctly and the correct voltages appear on the throttle and PAS hall connections, even trying swapping all phase connections etc..
I now have a lot of ebike parts, so I'm able to "mix and match" quite a selection when testing. I've tried those two faulty
Conhismotor controllers on three different hall motors, with two identical LCD control panels. I also have two other square wave controllers and two batteries, three throttles and two PAS sensors.
Every combination of parts spins all of the motors
except using either of the two
Conhismotor controllers.
That made me suspect the software settings in the LCD panel, but I tried everything, and have since used the same panel with a controller bought from Dave with the MXUS motor. Both the one that Dave supplied and the identical panel that came from
Conhismotor for the faulty controllers work Dave's controller perfectly, so I can now rule that out.
So, to loosely quote Sherlock Holmes, once you rule out the impossible faults, you are left with the only possible truth, however improbable it may seem,
both of the Conhismotor controllers are faulty.
and no further responses from Conhismotor.
