Hey all,
First of all nice to join your community. Normally I'm really good at scrapping the internet for topics and knowledge but I'm in a really, really difficult situation. You guys definitely seem like the best possible resource.
I ride an electric bike I built from my apartment to my job 5 times a week, back and forth. It's about a total distance of 14 miles. Recently, upon leaving work, I hit a small pothole and my electric bike stopped turning the wheel. I also didn't have the chain connected at the time so I was absolutely screwed.
The issue is, I can't figure out what broke.
Here is the technicals on the bike itself:
Wattage: 1000 watts
Volt: 48 volts
Battery: 72 amp 48 volt (12volt by 18 amp SLA-AGM Battery * 4 )
PAS Computer : 5 Speed Digital Computer with Special Controller http://www.conhismotor.com/ProductShow.asp?id=385
The Kit: http://www.ebay.com/itm/2013-New-48V-1000W-Front-Wheel-Electric-Bicycle-Conversion-Kits-with-LCD-Display-/231241750362?pt=Cycling_Parts_Accessories&hash=item35d715175a
Here is a list of symptoms and conditions after the incident:
I'm a smart kid, with a good job, but this is my only way of getting to work. I have NO IDEA what is wrong, and not much money. Does anyone have any idea what is wrong? I start work again Monday so any input or ideas is greatly appreciated.
Wattage: 1000 watts
Volt: 48 volts
- There is a lock that turns on and off the bike. It appears to work (power on/off)
- There is a throttle with a lock and battery indicator. It appears to work (lighted battery meter)
- Power turns on through the bike. (I hear a little click sound in the motor when I turn on the bike)
- Turning the throttle does not turn the wheel.
- The PAS sensor has always been disconnected. (I essentially used it as a scooter)
- The bike worked perfectly, except sometimes I would have no power to the wheel when I turned it on. I would have to turn off and on the bike again to reset something and then the throttle and wheel worked. (I don't know what I reset, but it would finally power the wheel)
- Sometimes I would have to repeat the above solution 2 - 8 times till I finally got the wheel to turn.
- The brake is not active. (As reported by the PAS Computer)
- Short the throttle connection (high to common) on the controller to see if the throttle was busted. The wheel would still not turn. (But it made a clicky sound when I released the short)
- I've opened up the controller to check for pop'd capacitors or loose wires. None
- The PAS 5 Speed Computer appears to be in working condition with no faults.
- Disconnected all wires and reconnected
- Yes, I've checked the battery.
