Hi there.
After my bad experience with powerscoots! I eventually ended up with a Cyclone electric bike (650w). While this kit was fairly solid the bike they provided on was not, and after 1000 miles the front forks had actually bent from the force of the disc brakes!.
The kit is now on another bike (slightly stronger might I add). But I am thinking of going down the path of a hub motor.
I have no idea what im looking at. There is soo much information out there and I know the forum users of the Pedelec forums are actually one of the friendliest and helpful bunch I have come across!
I am looking for either a Kit or a bike with a 1000watt motor in the hub or eleswhere. My bike at the moment can do 18-20 miles an hour on the flat, but the battery is on a shelf above the rear tyre which make the weight distribution a bit odd.
I also value the importance of good brakes which is why I have steered clear of hub based motors as they do not allow me to put my Hyro discs on the front.
By bike at the moment has about 13-15 miles range and its hill climbing ability is good as it goes through the gears. my commute is 9.8 miles each way and I charge at the office at the moment.
Im looking for something that will do 25-28 mph Easily on the flat and will give me at least 10 miles range.
Is there anything out there that meets my specs?
Thanks for all your help in advance!
Alexander Foti
Alexander Foti
