Coasting
Gubbins
Bought myself a new car last week, the same as I had before which has been really good so basically its just an upgrade.
The car is an A1 Automatic and in the 3 years since I bought the old one things have moved on a tad and I find among other things the Auto box not only has the std Auto and Sport modes but now has an E mode.. This does what you would expect by changing gear a bit earlier but also when you take your foot off it disengages the clutch and coasts.. This is quite effective and needs a slight change in driving style or you end up going around corners faster than you intended without the engine braking effect you normally experience.
but my question is this..
Back in the days when TRex roamed the moors and the unlimited speed sign meant exactly that I learned to drive, and I am sure that I was taught never to coast/free wheel, in fact I am also sure it would be a test fail for doing it..
My grandson has just passed his test and he had no idea what I was talking about, now my memory isn't brilliant, so can anyone back me up on this?
Artstu
2,421
925
I remember it as being illegal to coast, along with having your headlights on whilst parked. It seems the highway code has been dumbed down somewhat these days.
https://www.gov.uk/guidance/the-highway-code/general-rules-techniques-and-advice-for-all-drivers-and-riders-103-to-158
Rule 122
Coasting. This term describes a vehicle travelling in neutral or with the clutch pressed down. It can reduce driver control because
  • engine braking is eliminated
  • vehicle speed downhill will increase quickly
  • increased use of the footbrake can reduce its effectiveness
  • steering response will be affected, particularly on bends and corners
  • it may be more difficult to select the appropriate gear when needed.
Reactions: Beach Thorncombe
Zlatan
8,086
4,290
Its not new tho. Two stroke NSU was so uneconomical it freewheeled rather than applying engine braking...( two strokes have less engine braking to start with but NSU engaged a freeweel arrangement... I believe it centres around car not being under control and not necessarily freewheeling being illegal. Dad always called it freewheeling fifth ( in 4 forward speed days) which could be deemed not I control.( ie you have to physically engage gear) It happened automatically on NSU and I don't think it could be disengaged. ( mind many removed the 2 stroke and stuck in a ford engine) Think it was NSU Prince ) or Prinz) memory erosion and apparently faulty logic these days...
I,ll bet its one of those things nobody was ever prosecuted for..having said that I once got stopped for speeding whilst in freewheeling fifth. Officer exclaimed " you were shifting a bit "
My stupid reply
" you should see it when its in gear!!!?"
Never been blessed with much sense....typical leave voter ?( before OG gets back)
IIRC, the idea that you shouln't coast was based on the idea that you would'd have control of the power. That's not a problem for your car because it reengages the power instantly in the correct gear.
Edit: just read rule 122. That's basically wat they're saying. They include that you might not have good control and it can lead to brake problems, but your car has been designed to coast, so one would assume that the braking system has been appropriately designed for it.
Gubbins
I thought it was because back then the brakes needed all the help they could get. And you are correct it re-engages in the most appropriate gear when you touch any of the controls or it starts accelerating too quickly. Still feels wrong, but not in a bad way.
stevenatleven
215
141
Fife
I seem to remember it was frowned upon when I passed my test in the 60s.Something about no drive to the wheels made them lose grip ?
I remember a neighbour of ours had an early Saab and that had a coasting feature he used to tell us. I coast on my e bike all the time !
Reactions: Gubbins
Croxden
2,134
1,384
North Staffs
It was called the free wheel, Saab And Rover had it.
The police did not approved of their officers using it in their Rovers.
A bit of a bugger if you could not get the engine started.
grldtnr
627
288
south east Essex
I run a Skoda ,which has a DSG gearbox, essentially this has 2 clutches ,one for upshits, one for down, I reckon that it is one of the smoothest gearbox going, it drives slightly different to torque converter boxes, but sure is economical,
Gubbins
This is the same vw box as is in mine. Is yours a newish one.. do you have the E mode with coasting?
That DRAG device must sure cure constipation!
Reactions: Croxden
Tabs
279
132
65
Scotland
Pretty sure that now your told to coast when approaching a red light etc, back in the day I was taught to drop down the gears as you approached the red light, I also got taught how to go round a roundabout which is something of a lost art!!
Gubbins
To be fair tho. Some roundabouts can be confusing. We have one in Lawkholm lane that is a tight T junction and it was turned into a mini roundabout that you can't go around and arriving from town centre at it to turn right, the oncoming traffic which used to have right of way now has to give way and not all do!
30,844
That definitely was the case in the early 1960s and before, the era you're referring to. Coasting out of gear was regarded as not having control.
Still none the wiser, must be because your from the old country?
Got some figs and cod liver oil on order should it be me,but I feel fine!
It is very difficult to edit your own work. But if you read it carefully you omitted the letter f in the word upshifting.......
Croxden
2,134
1,384
North Staffs
It's not something I would want, I prefer it going downwards.
grldtnr
627
288
south east Essex
Oh! Err! Just when you want autospellcheck computer inserts the wrong word anyway systems botheration,.
Hadn't taken the cod liver oil or castor oil, system operating normally, not in overdrive, (pun intended)
