Clonk noise from crank
Simonwwfc
219
36
Hi all my 2020 oxygen mk11 mtb has a clonk noise coming from the crank area I can feel it through the peddles when you do a full cycle peddle it’s only just touched over 500 miles from brand new any ideas
8,528
Loose cranks, badly adjusted/tightened BB or worn BB bearings ?
3,993
At only 500 miles, logic says it's one of your crank bolts. Tighten it immediately.
It looks like you forgot to mention that you replaced the triple chainwheel for your single red one.
Simonwwfc
219
36
Checked this morning to see if they was loose but tight it’s seems when you put pressure on the peddle arms the knocking clunk starts maybe bottom bracket
Related Articles
