Hi,
I have a Kalkhoff Pro Connect 10 bike, purchased a couple of months ago.
I have done about 1,000 miles with it so far, mainly on flat towpaths (so with the minimum assistance most of the time).
Originally, some loud "clacking" noise came from the motor when I was using the maximum assistance level. However, today, the noise also started after about 2 hours when using the lowest "eco" mode one (basically, one loud "clack" per front sprocket full rev). Sometimes, pedaling in reverse for one full rev is fixing the issue, as if the chain was not engaged properly on the front sprocket.
I am sure it's not the chain, derailleur or anything else, as the noise stops as soon as the motor is switched off. The noise does not specifically happen either when changing gears, which are changing fine and the chain does not have to be changed yet.
I can see old threads regarding the Panasonic motor having similar issues, but this is an Impulse 2 Kalkhoff motor.
I am going to send my bike for a maintenance check to 50 cycles soon, but would be interested to know if other people have a similar issue with crank noise.
Thanks,
Tom
50cycles Statement (Feb 2016)
'After our annual service meeting with Derby Cycles it was pointed out to us that a simple software update will rectify the timing issues with both Pedal and Torque sensors that previously may have damaged the motor.
The result of this was a slight clicking sensation in the crank arm that if continued without the proper update could cause damage to the pulls which in turn would cause a lack of drive assistance leading to eventually a motor failure.
However this does not effect any warranties and has been dealt with promptly in all cases. For those customers that have been caught out of warranty they have been offered for their motors to be reconditioned. This error only occurred in a small volume of models during 2013/2014 models.
It has also been discovered that this error could occur by fault of the customer when either dropping the bike or having a collision that impacted the motor such as kerbing the bike with the riders full weight.
This potentially could cause a fault to the sensors resulting in a similar problem as above. However these sensor are covered under warranty and are dealt with as such. Again this only happened with Pre 2015 models and has since been resolved.'
Thanks,
Tom
