Chinese controller - how to derestrict it?
Michael Love
155
35
59
My falcon (piece of rusty crap) has a chonese controller exactly like this one....
http://www.pedelecs.co.uk/forum/threads/derestrict-falcon-spark.27729/
In mine, the white wire is also disconnected but the bike shuts off power to the motor, the power doesn't tail off.
What is this learning whit wire and what ate the other wires for.
Pics below.
The diagram is from ebay and matches until it getts to letter small c.
Can someone also please point me in the direction of what all the text on the controller means. I know all about electronics but not about speet set1. Or what tgey mean by brake level low
Thanks.
anon4
574
90
32
GB
Pics below.
Thanks.
If you attach a throttle these will happily chug along at the motors max speed
Michael Love
155
35
59
Yep, soneone said that to me already, thanks though.
I would love to know if there was another way. How does the controller know how fast wheel is travelling, is there a pulse wire or does it calculate the speed based on the hall sensor pulses in the motor?
Thanks.
8,525
What s the bikes current top speed ?
Not all controllers can be de-restricted, unless there is a linked cable to disconnect or potentiometer to adjust. Some allow access to extra speed via the lcd.
Low brake means that the wire carries 5v when not active, once brake is activated it reads 0v.
Speed set 1:1 means you have PAS.
Booster is throttle or three speed switch.
8,525
Thanks.
It calculates via the hall sensor/magnet passing in the hub if it has internal sensor.
Fat Rat
1,903
726
UK
Put the post in the Speed Pedelecs part of the site where you got the link from may help with your quest and make more sense
anon4
574
90
32
GB
Thanks.
I doubt it as it doesn't take an LCD to configure it. I think it's setup so for the US market where throttle and higher speed is allowed it will do it's full speed on a throttle, in the EU they just leave the throttle off as the pedal assist is restricted. If you want more options one of these should fit inside the enclosure and can be setup via the LCD: https://www.ebay.co.uk/itm/250W-350W-eBike-LCD-Display-Panel-Electric-Bicycle-Scooter-Controller-Ebike-New/323541096132?var=&hash=item4b548d56c4
