cheap voltage tester for light battery packs
6,733
awol
1,216
374
How do you set the voltages?
Also one of the pics shows a resistor between the 2 inner connections, is that needed?
6,733
there is a button on the back hold it for 3 sec and goes to the low batt setting then wait 3 sec and goes to the full batt settings 1-30v for both.
that is just my 18650 charger just batt box meter then light.;)
6,733
awol
1,216
374
Ordered one to try out. The resistor I mentioned is shown on the ebay pics connected to the 2 inner wire connectors but I think I understand it now, that is showing the load and the power to the 2 outer connectors.
Does it actually cut the voltage supply off when lower set level is reached?
