Cheap e-bike? £600?
Max1980
36
Hi guys, great forum!
I'm looking for a cheap e-bike option to get back into cycling. The plan is to do little day trips around London with my gf who just got a VanMoof. It won't be for commuting but it would be nice if I could swap some journeys. For reference I'm 5'7 and 140lbs. I would guess the range would need to be between 20-30miles.
Unfortunately I can't really justify spending big money at this point in time so I've narrowed it down to a few options. The goal is to end up with something fun that I can grow with.
1 - Used Carrera, Lombard, Chinese fat bike - These can be had for £600ish but the obvious worry is that they will have no warranty and if anything goes wrong parts could be hard to get hold of.
2 - New Amazon/Chinese bike - Brand new, 1yr warranty, good reviews but what happens if something goes wrong in a years time? scrap heap?
3 - DIY my own bike - If I don't go super high end in theory I could build something pretty cool. I have to admit I'm drawn to the UDX look, retro BMX cruisers etc
Any advice?
Bonzo Banana
807
465
Wow that is really cheap! £150 for this and that's the whole kit (I think) for £200.
This is the other one I'm looking at. I believe it's from the same line.
BFSWX02 48V 500W - G020.500D/DC mode
https://www.amazon.co.uk/Conversion-Wheel-Electric-BAFANG-Display/dp/B09R7TDWHJ?th=1&psc=1
I guess the question is whether it's worth spending more for the native 48v hub kit?
That top amazon kit wouldn't be suitable for the Bafang based wheel. You need to pair the correct type of controller, that sports direct wheel will be 250W/350W and will need a suitable controller with the correct connector for the wheel and there will be other important parts of the spec to match. I think I've read such a wheel can be paired with KT-15A and KT-17A controllers with the correct cable to match that motor but you'd need to do some research with the seller to check for compatibility. A quick look on amazon shows this;
Which seems to have a suitable connection for the Bafang motor. Also its dual 36V/48V so in theory would work with your existing battery but then how would the Bafang motor cope with 48V when designed for 36V. A quick look shows the Bafang motor under its older product name has been over-volted to 59V. The G020 is the new name for SWX02.
Unfortunately though until you have the sports direct wheel in your mitts its not worth buying anything extra. They have a poor reputation for customer service and over-selling or mis-describing products so you could end up with nothing or something very different to what you expected. They could have only 3 of these wheels to sell but taken orders for 50 etc. If they have loads then why? Perhaps the bikes came fitted with the wrong hub motors and so they have had to sell them separately and wait for replacement wheels to fit to the bikes. If they are the wrong motors then they won't be as description. Likely higher wattage motors perhaps not legal in the UK market etc hence the big discounting. All a bit of a mystery but definitely worth a punt for a Bafang hub motor at that price.
Reactions: Max1980
Max1980
36
Have ordered the hub, will be interesting to see what turns up tomorrow:) much appreciated, I'm quite excited now!
Totally missed the controller connections, nice one thanks. Need get my head around that too. The KT-17A and LCD3 seem to be frequently recommended so that seems like the route to go, well within safe range for battery and can limit the maximum draw if needed.
If I understand correctly the 36V hub run at 48V will give me 25-33% more speed and torque at the original 7-15A draw and still acceptable 30-60m range.
Max1980
36
will be interesting to know whats written on the hub..............
It's shipped, looks like I got the last one.. my guess is the original bike is out of warranty so they are selling the spares. They don't sell any other Ebikes with the same rim size.
Bonzo Banana
807
465
I ordered one myself and also shipped so we will see what happens. Best of luck to the both of us. Yes they may have had a certain number of spare wheels for warranty claims but then found out the hub motors are more reliable than they expected and just weren't using those spare wheels. There is a video on youtube of the Bafang factory and they buy all their hub motors from another factory but assemble them themselves and have a great testing regime so typically Bafang motors have a excellent reputation for reliability because they go out the door with better final assembly and proper testing which isn't always true of other manufacturers. Maybe Evan's were used to other hub motors with a much higher failure rate. In which case its an even bigger bargain.
However with that said it could all going horribly wrong being sports direct and we get something nothing like the description and will have to rely on their not so awesome returns process. What else could they claim to have a £255 value on such an ebike though. It's got to be the motor but will it come laced to a rim or just the hub motor if so this will be the first wheel I've ever fully laced or will it be the wrong model wheel which they bought as spares but were actually fitted with the wrong spec motor not suitable for the Mercury. I've seen the Pinnacle Mercury get some pretty glowing reviews, often described as a Carrera Subway ebike beater as it has a more reliable motor setup than the Suntour HESC system of the Subway. Although the Subway has a torque sensor so delivers its power in the same way as most mid-drive ebikes. However most people will take reliability over performance and poor reliability.
Reactions: Max1980
Bonzo Banana
807
465
I think the 13 at the end indicates windings which the more you have means more torque less speed I think and will mean the current draw is less so perhaps better suited for the fairly low capacity battery of the Pinnacle Mercury. I can't see the other side is it a freewheel thread or a freehub on the other side. I'm a bit confused by various specs online they say 36/43/48V but is that different models or the same model is compatible across all voltages. It reads like 48V compatibility is standard to me and you aren't hacking it as that is official.
The hub has hall sensors so you need a controller that supports hall sensors I believe. I think most of the cheaper ones support hall sensors but not sure or I may have got completely confused on that issue. Mines been despatched but I only went for cheapo standard delivery. I ordered 2 days before you so I'm presuming you coughed up for fast delivery.
This could be a case of the blind leading the blind as my ebike experience is not as extensive as some of the posters here so hopefully we can both get working ebikes out of this discounted wheel.
I was going to use a Pinnacle mountain bike frame that I had but now realise that is a 29er frame so I have a 27.5" Saracen frame I will use instead. I've got everything I need for the build except I'm not sure I have any particularly decent forks, probably have some Suntour XCM forks to use. The battery I have is a 48V 15Ah.
Reactions: Max1980
Max1980
36
@Bonzo Banana Yeah I couldn't wait :D It's a freehub I believe. The specs are all a bit confusing, my guess is it's just one model and companies just spec the windings and voltage they want. I'm guessing this was specced to hit the UK speed limit. I think most legal 48V kits use code 16 for the same reason.
Just reading this thread and it seems Woosh used code 13 for their Rio which had the same hub. They say it's safe up to around 24mph at 48V which points to a 17A controller. Should be more than enough for me!
That Saracen looks lovely! Can't wait to see the finished thing.
This hub has definitely opened up the budget a bit. I think I can get into something second hand with hydraulic breaks and front suspension (bad wrists). Somewhere between £150-250.
Bonzo Banana
807
465
I'm not 100% sure of the frame yet as when I try to fit the hub there could be issues with dropout spacing and the dropout design. I may go with a frame with the beefiest looking dropout that will best fit a torque arm. However I have the Saracen frame and I think a Carrera Subway frame and that's it at 27.5" I wish I had a 27.5" steel disc frame to be honest. Makes life easier as you can bend dropouts if you have to and the material is denser so if you have to file out a dropout to suit its less compromised plus they are generally a stronger frame. You will need a torque arm, running 48V through it and its a pretty high torque motor hub anyway.
Once fitted it will be a little more difficult to remove than a standard rear wheel with quick release so bear this mind. You may want to run tubeless so you don't need to remove the wheel to repair punctures or you may perhaps want to go with a downhill inner tube and maybe a tyre liner. Just ways of reducing the need to remove the rear wheel.
Reactions: Max1980
Max1980
36
I've seen a few Subway conversions, here's hoping it's straight forward!
I'm looking at a Carrera Vulcan locally as it has front suspension and hydraulic brakes. Should be well within budget even with new wheels. The 27.5" size has limited the options somewhat but it's not a massive issue.
Now to source a controller that won't take a month to arrive!
Bonzo Banana
807
465
I'm keeping to mechanical disc brakes just so I can use standard cut off brake levers.
Reactions: Stan464
Bonzo Banana
807
465
My wheel has arrived, very minimal OEM packaging. Includes a bag of nuts/bolts etc but no paperwork at all included with the wheel apart from receipt on the outside of the box. Definitely looks fairly small, not much surface area to dissipate heat and can't be a particularly large planetary gear setup. Still bigger than a lot of geared hubs you see nowadays like the Swytch kit hub but as someone used to direct drive hubs very small. Very nicely made and a freehub, amazing value.
Reactions: Max1980
Max1980
36
Finally found some time to get back into the project. I managed to find an unloved Carrera Vulcan that used to be an ebike conversion for £100. Ideally I would have spent more for one in good condition but there isn't much available locally. It's a bit of a frankenbike at the moment unfortunately.
Anyway -
Couple of issues -
1 - The shifters are 8 speed but the rear cassette is a Shimano HG400-9 which has 9 cogs. I am unsure what size chain is on it currently.
Does it matter if I can't get to the smallest cog?
If so am I better off buying 9 speed shifters, removing a cog (assuming this is possible) or swapping for an 8 speed?
I'm planning on paying a local bike shop to sort the gears out once I've got the wheel fitted at least.
Bonzo Banana
807
465
Anyway -
Couple of issues -
If its a 9 speed cassette I would go for a 9 speed shifter as the cheapest solution unless of course the 9 speed cassette is heavily worn and you might as well just get a 8 speed cassette anyway.
Aliexpress does reasonably priced shifters. I've had a quick look so not recommending this as you may find cheaper;
If you see a chain that says 5-7 speed compatible its a 7 speed chain which will also work on 5 and 6 speed but may not last as long as has thinner side plates. So if you have lets say an 8 speed cassette and a choice of a 5-8 speed chain or a 8-9 speed chain the 5-8 speed chain is the best option as its an actual 8 speed chain but still works on 5,6 and 7 speed cassettes.
Do you have a picture of the bike you bought, I'm curious plus if you have any additional questions it helps to see the bike you have.
Max1980
36
Ok so list of random parts -
Shifters - Sram X4 8 speed
Front Brake - Clarks Lever and Meroca M800 piston Hydraulic
Rear Brake - XOD e-bike hydraulic (has cutoff built in if I buy the wire)
Front Dérailleur - Shimano Tourney 7/8 speed
Rear Dérailleur - SRAM X4
Max1980
36
I think I'm going to avoid Aliexpress purely due to shipping times. If I can get a suitable 8 speed cassette I can get started right away.
Do I need an 11-28 cassette or 12-32?
Bonzo Banana
807
465
You would probably get away with 11-34T if you wanted that.
You need to find the spec of the X4 derailleur for its year, what length of cage it has (there may be multiple models with different cage lengths) and find out its rear capacity. You only really need to do this if you are attempting a wider cassette than normal like a 11-36T. I'm sure a 11-32T would be fine without having to work anything out.
Looks a nice bike with some decent components although they do seem a bit random.
Reactions: Max1980
Max1980
36
Thanks mate, went for the 11-32T. Fits fine. Still waiting on other bits.
I got a Schwalbe Marathon Plus SmartGuard MTB Tyre
https://www.wiggle.co.uk/schwalbe-marathon-plus-smartguard-mtb-tyre
Price seems good and apparently a great choice for eBikes.
Of course I had no idea rim tape was a thing so now I need to figure that out too. Have you got any suggestions?
Max1980
36
Ok so here is the running total so far -
£100 - Bike, hydraulic brakes, front suspension
£100 - Yose Power 48V 13A Battery
£60 - Bafang G020.250.DC 13 Motor on a 27.5" rim
£77 - 17A KT Controller, throttle, brake sensor, LCD3 display etc
£27 - Schwalbe Marathon plus MTB Tyre
£4 - Schwalbe innertube
£3 - Schwalbe rim tape
£23 - 8 Speed Cassette
£5 - Brake pads
£4 - Throttle Cable
£10 - New Handlebars
£14 - Hyraulic brake fluid kit
£2 - Rivnuts
Grand total = £429
I was getting a bit antsy last night so I powered on the kit just to check it is working. All good so far! Annoying having to wait for this rim tape but it's not the end of the world
Just need to buy some sort of pouch for the controller and give the whole thing a clean.
Reactions: lightning
