Special deal for 6 more days, haven't used but pretty standard T6 and battery pack $25.90 aud.
http://deals.dx.com/team.php?id=4388
http://dx.com/en/p/5-4mm-male-to-female-extension-cable-for-sku-29489-30864-100cm-32751I got one too and it's pretty good value. Nice and bright with flashing modes. I just wish the cable to the battery pack was a bit longer.
Fit a short fly lead with inline plug, and fix it permanently to the ayup (araldite for waterproofness).It certainly looks good. One of the problems I have with my old Ay Up light set up is that the socket for the light unit is built in to the actual light and this socket is getting worn out after about 6 years.
Take a look at waste fittings - some have large o ring seals, which you can buy as sets in big diy stores, or individually at plumbers merchants. The lights can also be permanently mounted quite easily. HTHJust one question - can you purchase replacement small rubber bungee cords?? These will wear out eventually.
They strap to the handlebar with an O-ring sort of thing, which holds the light firmly enough in place, but it's still easy enough to point it down or up, like a sort of manual dipping. I don't think it would bother too many car drivers when on low power mode. In any case, you could easily make a hood for it out of a bit of plastic sheet to stop the beam straying up to eye level; however, it's still a small light, so a bit of dazzle gives it more presence and helps ensure that drivers will dip for you on unlit roads. I've never had anybody flash me yet when it's on full power, and they nearly all dip. If they don't, I just tilt it up a bit, and then they do.Also, just a couple more:
1. Is it still too bright for on coming cars in Low mode?
2. The charger supplied - does it come with an adaptor for UK sockets? If not, what voltage and mA rating is the charger?
Forgot to mention that you can get diffusers to fit these lights that give a flat beam spread - no danger of dazzling oncoming traffic then.Also, just a couple more:
