I've built a 44volt Battery Pack with 9 14.8v 5ah hard case lipos at the moment this is run with a 250 watt hub motor all runs well my problem is charge the thing it takes far to long with imax6 charger I've charged them separate and together as the whole pack & as as an 3 battery pack
I can only use this pack every other day as what with sleeping & work & the charge only works for 120 minutes at a time lucky I still have my 10ah battery on the bike as well my journey to work is only 10 miles round trip so this has no problem coping with this but 12 miles is about its limit but I would like some advise on a suitable charge for the job
also am will be upgrading to a 36v 800watt or 48v 500watt rear hub which would you think would be best suited to this battery may add 3 more battery later for a bit more range
