Thanks Dave. I have two of this batery so if it possible to charge them all together?I used these ones for quite a while and they're quite adequate. You need a 5amp or more 12v power supply as well, which you can buy for about £5 or use a PC power supply, or a Playstation one, etc.
LCD Digital IMax B6 2S-6S RC Lipo/NiMh/Li-ion/LiFe/Nicd Battery Balance Charger | eBay
I now have this one that's a lot better, but more expensive. It's simpler to use because it charges and balances the cells individually through the balance leads. It still needs a power supply. A PC one would be better for more amps, which speeds up the charging:
BC168 RC Model Super Speed Li-ion Li-Polymer Li-Fe Hobby Balance Charger BC016 | eBay
You can charge them together if you parallel them.Thanks Dave. I have two of this batery so if it possible to charge them all together?
My battery setup is the same as your Jetstream P8.
Thanks.
Pat
But just the snobs on here use a switch or light, mines hard wired in.Just in case any ones wondering how to get a pc power supply to start up when its not connected to a motherboard ..
Just connect pins 13 & 14 with a paper clip, or for the deluxe mod use a switch
full details here ..How do I run my ATX power supply without a motherboard? Overclocking | DSLReports.com, ISP Information
have a look at giantshark in the uk.Hi everyone,
I am looking for a charger for this lipo pack?
Which one should I get? I believe the charger can balance the cell as well right?
thanks
Pat
You just need a parallel charging board that costs about £10 or is free with the BC168 charger.Thanks Dave. I have two of this batery so if it possible to charge them all together?
Thanks.
Pat
Is it really that simple, take a PC PSU and "connect pins 13 (power on) and 14 (ground) with a wire or paperclip"? Are the connections "always the same", or it could be the connector of the PSU and the charge connector of the battery do not fit?Just in case any ones wondering how to get a pc power supply to start up when its not connected to a motherboard ..
