Charger For Kalkhoff
DavieH
51
Elderslie Scotland
Hi I have a Kalhoff Endeavour s10 I am looking for a charger for it.
the one from 50 Cycles is £139 so its a bit of a ripoff does anyone know of a charger that will fit it.
I think yours has a multi pin charging connection and is a base type that the battery stands on, so a normal two connection charger won't suit.
I can only suggest you go online to see if you can buy the correct one cheaper from Germany.
4bound
172
86
Neston
www.facebook.com
Are you looking for a second charger to keep in a different location? I was and spoke to 50cycles about this, since I too was reluctant to pay £139. They did point out that all I needed to do was carry the actual charger, not the cradle since the charger can be plugged directly into the battery, I hadn't realised I could do this off the bike in advance of purchasing it. This method has worked well for me.
I was so pleased with the bike my wife now has a similar one, so we have two chargers after all - and better still I have access to a second battery for longer trips.
