Changing Wheels...Cube Bike?
8,534
You will need new tyre as well.
The next feasible size down is 27.5"/650B the O/A rim & tyre diameter is approx. 38 mm less, the drop out widths will then decide on how fat a tyre you can fit. A 26" rim/tyre is approx. 63mm less in diameter then 29".
Reducing tyre size then changes geometry and height, crank/pedal strike then becomes more likely on rougher terrain or turning esp if you are a leaner.
Saddle and bars will need raising as well.
Reactions: Deanjay
Deanjay
13
Thanks Neeth! I’m new to the bike scene and have a lot to learn! I think on budget terms, could I fit wider tyres on this bike? The Schwalbe GT Tours are ok for the road, but feel hard. I’d like a fatter more absorbent tyre?
tha ks for your previous reply
TobyAnscombe
124
24
Epping Forest, Essex
Assuming that you are just looking for comfort as opposed to any other reason then the first thing I would do is drop the pressure in the tyres. Changing wheels is not a small job and will totally change the geometry of the bike and probably not in a good way...
8,534
I'm now more confused is the Op looking for different tyre width or actual wheel size ?
