Evening, I'm looking to change my throttle from a wuxing 130x to a 108x as the 108 looks to be more waterproof. My handlebar configuration needs a left hand throttle. I managed to find a left hand but not from my controller supplier (topbikekit only supply RH version of 108x).
When I connect the new throttle my KT controller gives a throttle error so for now I have unplugged and put the 130x back on. I suspect the wiring order may be different. Is there any way to identify the correct order? I'm reluctant to use trial and error as I don't want to blow anything.
The connectors are 3-pin Julet so I can't easily see any wire colours at the controller end.
I'm surprised that the same connector would be wired differently from another supplier.
I could use a meter on the pins in the connector from the controller but not sure what values to look for or if this is even possible.
