Hi All,
I have a Raleigh Velo XC and posted here about it last year, regarding intermittent problem with pedal assist. Finally took it in for repair this week, and bike shop have advised it is the Torque sensor that as failed - in fact it has actually broken in half. They contacted Raleigh and the Torque sensor is no longer stocked part with them. They have given me the manufacturer details - IdBike based in Holland, so I have emailed to ask if they still supply them and get a price. Today we stripped the Torque sensor out ourselves, and have superglued the broken side plastic back together. Leaving to cure overnight and will try it tomorrow. I am wondering if it would be possible to change the TMM to a cadence sensor on the crank. Would this need a whole new controller etc, or would the signal still trigger the motor from the cadence ring if wired into the circuit? I have just the exact same bike listed on eBay and it seems to have the TMM disconnected (see below) and has had a cadence sensor added, so looks like someone else has had the same problem. Any advice appreciated, thanks
