I've just bought a Cube Town Sport Hybrid Pro for commuting, ten miles each way and 50/50 road and cycle path.
Standard chainring is 38T but I'm not using the lowest two gears at all; the steepest slope I encounter is a speed hump.
Before I start attacking a brand new bike with blunt instruments I thought I'd ask for advice.
I'm considering fitting a 42T chainring, a 10% change which should allow more use of the lower gears and slower pedalling rate.
What affect, if any, will this have on the motor, a Bosch Active Line Plus Gen 3? The speed sensor is on the rear wheel so I expect the 15mph cutoff won't change, but will I get
more assistance as the pedalling rate will be reduced? Does this risk overloading the motor?
Probably the first question I should ask is, is it worth it? I'll need new sprocket, chainguard and tools to remove the crank.
Will the difference even be noticeable?
