I ride a Haibike sDuro HardSeven SL 2015 Yamaha and have covered 1600 miles since March 2015. I commute about 23 miles return trip to work with 13 or so of them off road. I have had remarkably few issues with my bike however with the advent of wetter weather I have suddenly become afflicted by the dreadful Chain Suck phenomenon. This is where your pedalling comes to an abrupt jamming halt, usually while you are pushing hard on the pedals climbing a hill! Just where you want to stop! I am no mechanic and did not know what causes it. I asked a friend who said it happened when the chain does not release from the front sprocket where the teeth have become slightly hooked with wear and the chain gets pulled around and jams. He suggested changing the transmission with a new front sprocket, cassette and chain.
I was about to do this but had wanted to keep my old transmission on the bike during winter and put a new one on in the spring being a bit of a skin flint. I googled chain suck and found chain suck in a nutshell. There I found a way of getting rid of chain suck by filing hooked teeth to allow the chain to release normally. Well I thought if I am going to have to replace it anyway I might as well give it a go. I turned my bike upside down, lifted the chain of the front sprocket and had a look. Sure enough I found a few hooked teeth. I carefully filed every tooth just enough to remove the hooking. I then took it out for a muddy ride and to my surprise I had cured my chain suck! There was no chain slippage and it all worked as it should do. Now I am sure I will need a new transmission in the not too distant future but I have to say it has completely cured the problem. I owned a good file and the whole operation only took a few minutes. The teeth on my sprocket were not in terrible condition and a new sprocket might be a better approach if your sprocket is obviously knackered!
I have now covered 75 miles on the road with chain and sprockets working perfectly. Next week I will be doing another 92 miles (depending on weather) with 52 of those miles off road and will report how I get on.
I know there are different philosophies to chain and sprocket wear with some recommending changing the chain as soon as it reaches the wear limit and others just saying not to change the chain and just to use it until the chain is completely knackered and then change the whole transmission with new cassette, chain and front sprocket. I did try the changing the chain at wear limit approach but now find the wear it out approach better for me.
Whatever approach you take you need to keep the chain and sprockets clean and lubricated.
I am still new to the site and did post this into another forum posting and also tried sending a message from which I got very useful information from Fordulike about chain care and a comment from EddiePJ about how the small front sprocket on the newer Bosch drive can be badly effected by chain suck but was cured for him by engaging the clutch in the rear mech
For those of you riding through the winter months and venturing off road I thought it might be a good thing to have a wider discussion about.
