Fitted a DNP 7 speed freewheel 11-32T about two months ago. Must admit some of the teeth looked like they had been cut with an anglegrinder. But fitted anyway with 7 speed nexus twist shift.
Everything O.K. 11T gear was grindy no matter what the adjustment. But from previous forum searches others had this too, along with advice not to push hard on this gear.
Fitted a new shimano CN-UG51 chain today. With the rear wheel up all gears changed nice and smooth. On the test run three middle gears were slipping, with any load on.
Checked derailleur everything O.K. Checked chain links were free. Bent them side to side - all free, lubed chain again - still slipping.
The chain runs smoothly when turning the pedals backwards in each gear - no lifting, or catching.
I know i should have changed the chain the same time as the gears, but after less than 300 miles i thought the new chain could bed-in with the gears.
Would cycling a lot of miles start to bed in the drive train. A new DNP is only £26, but would it be just as badly made - the teeth on the orginal 6 speed Shimano (14-32T), which has done 2000 miles, looks much better job.
Bought equivalent KTM chain - no better.
Both chains were fitted with the same number of links as the orginal, and were correct size.
I do like the extra gear, it brings my average speed up 2/3 mph.
