chain link
musicbooks
719
29
Hi,
Yesterday coming back from work, my chain started crunching every 3 or four turns. When I got home I checked the chain and one of the links had popped off its sprocket and was bent out (hence the crunch). With a pair of pliers I popped it back on the pin and squeezed it straight. I did a test cycle and all is well. However, I am concerned that the chain is now weak. Is it likely to pop out again and should I replace the whole link or even the chain.
Thanks in advance for advice.
BW
musicbooks
30,775
If you mean one of the side plates had come off the chainlink pin, it could have happened if something like a small stone or piece of metal had got between a sprocket tooth and the chainlink, forcing the plate out.
If that's the case, it will probably be ok now since there's normally almost no side thrust to worry about.
musicbooks
719
29
That's right, T, the side plate had come unstuck from one of the pins. I squeezed it back together with pliers and all seems well. Just worried that it could fly off half way down a hill (or up)
Thanks for your help and reassurance.
T
BW
musicbooks
Mussels
3,207
Crowborough
If you are worried about it coming out again the the SRAM Powerlinks are a good replacement. You don't need to fit it straight away but it could sit in your toolkit so a snapped chain doesn't mean you have a long walk home. Just don't buy the version in Halfords, it is utter rubbish.
When my chain snapped I was very thankful to have a hub motor. :cool:
30,775
I'm afraid the otherwise excellent Powerlinks that Mussels mentions are only for derailleur gear chains.
Your Agattu hub gear chain is a wider 1/8" pitch one which can't use them, but after removing the offending chain section you can use one of these clip type connectors which are available from any good cycle shop. The rounded end of the retaining clip is mounted at the front in the direction of travel:
Lloyd_50cycles
65
Nottingham
I wouldn't personally recommend this type. They do fit the chain, but don't work very well with the Panasonic motor unit. The extra width of the link makes it prone to catching on the motor sprocket and chain tensioner. I would recommend keeping a chain tool in your kit, as even with a clip on link you could still find yourself having to use a chaintool to push out a damaged link should you snap your chain.
All the best
Lloyd
musicbooks
719
29
All the best
Lloyd
Thanks Lloyd ( and everyone) for the advice. I'll keep an eye on it. Could you recommend a decent (and cheap.. I am Scottish!) chain tool?
bw
musicbooks
30,775
Decent bike shops stock various types Tom, some larger and easier to use and some more compact for on road use. Here's photos of a couple of typical types, one larger, one small. See below for how to use, and expect to pay from about £8 to £15 for the larger budget tool:
The following link gives advice on how they are used:
Chain tool advice
musicbooks
719
29
Thanks for your help guys,
I'll let a few moths out of the wallet and see what I can afford:D
bw
musicbooks
john
531
Manchester
With some chains, once a pin has come out you have to replace it with a larger diameter pin or it will not be tight enough.
Mussels
3,207
Crowborough
bw
musicbooks
New chains are £4 each so it may not be worth messing about with fixing it. If you've done a lot of miles the cogs may need replacing with the chain and it can get more expensive.
