As I've now retired from work the bike no longer gets used for the commute so I'm building a crank drive for my full sus and thus the MAC kit is getting sold on. Details as follows:-
Upgrade EM3ev vers. Mac , 500/1000W Pick'n'Mix Kit
- Controller Type: 9 fet 30A (36-72V, IRFB4110)
- Motor Speed: 255rpm loaded @36V 10T Upgrade
- Front/Rear Motor: Front
- Wheel Type: 700C Alex DH19 CNC
- Throttle Type: Thumb Throttle
- Ebrakes: No ebrakes supplied but connection is available on controller/cav3
3spd switch
Bar mount power switch (no drain from battery if left plugged into controller)
V3 Cycle Analyst Ebike Computer, CA-DPS
EB3 Program Cable
Kit does well over 40mph no pedalling on 15s lipo but I have the CAV3 set up for three defaults - road legal (8mph, 12mph, 16.5mph - low power), go nuts (17mph, 25mph, unlimited - 1800watts) and economy (25mph max speed, 3 pos switch to select 350watts, 650 watts, 1000 watts).
Build photos here:- http://www.pedelecs.co.uk/forum/electric-bicycles/9442-new-build-16.html#post191603
Only done 300 miles since installing.
Buyer needs to know this isn't a starter kit - it's a powerful peice of equipment and needs proper installation seeing as it's a front kit - all c washers and torque arms will be included. Also, the CA V3 is techy peice of kit - it's quite involved (but brilliant) see here for the manual - Endless-sphere.com • View topic - Cycle Analyst V3 preview and first beta release I can reprogram the controller/CA V3 for whatever battery you're going to use but you can do it yourself with the provided cable. NOTE:- Controller has been painted black.
This all cost me £500 inc del and taxes - yours for £350 delivered anywhere in the UK and no need to worry about import duties
Willing to sell minus the CA v3 for £250. I'll supply a twist or thumb throttle with a longer lead so it can plug into the controller not the CA v3.
Payment via direct bank transfer or paypal gift.
3spd switch
EB3 Program Cable
