I purchased my Liv Vall-e Pro (2018) 10 months ago. The bike has been approximately 300 miles, after 150/200 miles I had a few problems. When pedalling, in particular up a small hill, the pedals jump and ‘clunk’, this only seems to happen on the two smallest ones. Initially the jumping was only minor but in the last few weeks this has become a big problem, so much so that the bike itself has lost power and will only restart after removing and reinstalling the battery. The bike is mostly used on weekends around local forest trails and on relatively flat roads in the town.
I took the bike to Giant/Liv for a service and was told that there was slight wear to the cassette and they adjusted it. The problem still occurs. Is this normal for a bike that has done less than 300 miles?
Currently it has the ‘Shimano HG-M6000 11-42 T, 10-sp’, any advice on a reasonably priced alternative?
Any help is much appreciated!
As Soundwave correctly mentioned, middle motor bikes are sadly liable to a much higher drive chain wear, and need constant maintenance to preclude such wear for as long as possible.
On middle motor e-bikes, the chain, cassette and front ring, pass ALL the motor power and ALL the rider's power as well, for which a normal bike chain and other components, was apparently never properly designed to do.
E-bike's with hub motors (front or back), pass all the motor power directly to the wheel itself via the spokes, not via the chain and its components.
On hub bikes, the cassette, chain and front ring ONLY pass the biker's power, just as in a normal pedal bike.
But due to the fact that the motor power passes to the driven wheel directly, most hub bike's chain drive, seen over long periods, probably actually pass less power, especially when the rider is not riding as strongly - or resting by free wheeling, and letting the motor take the strain!
This results on hub motor e-bikes, that the cassette, chain and front ring, wearing far less than any and all mid motor bikes, and usually even less than any conventional bike as well.....though that is not a given, as it depends on too many different rider factors.
And until middle motor bikes are drastically redesigned from scratch, to say supply motor power to the rear wheel directly (that must be possible!) and NOT via the chain, that problem, and a few others will remain - sadly for many mid motor bike owners.
It is and will remain a strong "Bone of contention" here on Pedelec and other biking web sites, one side criticizing the poor life of such mid drive systems (ME!), and the other ones who accept that it needs massive maintenance, because they actually own one!
The last people are often very vocal and rude, in them trying to "nay say" the problems, which are, once pointed out in a friendly and exact manner, are usually then obvious to even very un-mechanical people.
Sadly, I myself am regularly attacked in print, by such morons at least once a week here on Pedelec.
Its par for the course as I see it!
I then answer back in a similar manner, which sends them off like moronic sky rockets!
Wait up, they will start here soon.....
Basically, here on Pedelec sadly, several times a month, people with mid motor bike problems of one sort or another, come here as you did, trying to get a long term fix......but a 100% fix, IMHO, there is none, though your problems have come particularly early IMHO on your own bike.
Dear Avc97, if you wish to contact me privately here on Pedelec, I can supply you with further details and explanations, away from the "rebel rowsers."
But your choice either way of course.
If you don't know how to do that, just mention it here and I will contact you directly myself.
There is an excellent Personal Message service on Pedelec, that you can use to speak to one particular person, without any others spying on you, or what you write, and making rude unfriendly comments!!
Please notice that even though I know all the usual " Mid Motor Rowdies" here, I HAVE NOT MENTIONED A SINGLE NAME OR AVATAR OF ANY OF THEM! Up to now that is!!
Though of course they are well known by all members here.....just because of their exceedingly poor attitude and complete lack of basic human manners, and they will STILL feel that they are being directly addressed by name!!!!
Regards and best wishes for a great weekend
Andy
