I'd say that wear has more to do with the conditions that you ride in and riding style than anything else.
As said before, the conditions where I live are very hard on final drive components. We have three types of soil, Wealden clay which doesn't particularly do much harm, but is very heavy, chalk, which tends to dry chains out very quickly and often in less than 20 miles of riding. Then we have the worse of the lot, very acidic forest soil which is made up of extremely fine almost talcum powder sand. This absolutely destroys chains and acts as a cutting paste. I've yet to work out if it worse in the winter or in the summer when it just becomes dust. It can destroy chains in under 200 miles.
I have recently replaced the front sprocket, cassette, jockey wheels and chain after just over 600 miles on the KTM. I have also spotted today after hearing and feeling an odd noise, that I have managed to break the connecting link on the new KMC chain as well.
I certainly feel that the small front sprocket does no favours to sprocket wear, but I have been giving thought to the subject of wear over the last couple of days. You can't tell from the photo below, but the first three low gears on the cassette have had it. The reason being that that is where the bike spends most of its time, and this in part also adds to chain wear, as the chain is seldom running a straight line. I worked out or suspect that this wear has more to do with my riding technique than anything else. If left in tour, the battery could be drained from full charge in approx 20 miles of riding, so I tend to ride a combination of eco and no assist. Clearly by doing so, this means running lower gears, so placing more strain on everything, but range increases to approx 40 miles.
The combination of riding style and soil conditions helps nothing. The wear isn't limited to just the e-mtb though. Again as said before, I am now using the pedal mtb more and more, as the weight saving is pretty much compensating for my e-mtb riding style, and I'm finding riding it more fun. The wear of components though, isn't massively different when comparing the two bikes. Rear cassette wear is certainly better in the first three gears, but chain wear is the same, and the front sprockets are taking a hammering. I'll be replacing the whole lot very soon, and the mileage will be pretty much identical to that of the e-mtb
New chain and old chain.
